Anyone using liftbars?
Old Feb 20, 2022 | 01:43 PM
Bernie987's Avatar
Bernie987
Default Anyone using liftbars?
https://liftbars.com/
Looks like a cool, safe, timesaver. Anyone using them have any insight?
Old Feb 20, 2022 | 02:24 PM
Zach L's Avatar
Zach L
Seems relatively expensive compared to other options.
I use the BRS Jack Point... have used on 3 different Porsches with no issues. Fabspeed has a version too.
Old Feb 20, 2022 | 05:09 PM
plafondles's Avatar
plafondles
I have a set on order.
Old Feb 20, 2022 | 05:35 PM
Dave in Chicago's Avatar
Dave in Chicago
I use them and like them for working on my Boxster. You'll need a low clearance jack and mind the type of jack stands recommended (cradle type). The bars are heavy but work exactly as shown. I use a Harbor Freight jack with I believe about 3 1/2"? min height and 4 Torin Big Red 2 ton jack stands for my purposes. Quick Jacks look cool. I just don't have the storage space or patience for another device in the garage. Liftbars hit the sweet spot for me.
I lift whole side of car, insert jack stands... lower and do other side. If I'm going higher than a relatively low stand height, I alternate so as not to be angling the car too much side-to-side during the lifting process. I'm super careful that way. I know the car will be solid when I'm done, I just don't want to slide it off of the stands in the process by being impatient.
No commercial interest, just a happy customer.
This is an example of a pretty typical oil change position for me.
On LiftBars + std jack stands.
Old Feb 21, 2022 | 09:24 AM
zuch's Avatar
zuch
I have a set and use them anytime I'm doing brake or wheel cleaning work. I have had them for a few years and recommend them.
Old Feb 21, 2022 | 12:08 PM
Zach L's Avatar
Zach L
Their website says not to use those specific ESCO rubber flat top stands. I guess it's not too much an issue.
Old Feb 21, 2022 | 12:56 PM
zuch's Avatar
zuch
Thanks Zach. I used to use the Harbor Freight ones...but they were recalled. I bought these for everything else I do and didn't even think to check. So far no issues, but thanks for the excuse to go get some new stands (I think I can just get the "u" bracket for these).
Old Feb 21, 2022 | 01:19 PM
daylorb's Avatar
daylorb
I have a set, super-handy. With a Spyder I need low ramps though to use my jack. I did buy a quickjack on one of the sales though - as much as I like the liftbars, just got too tempted.
Old Feb 21, 2022 | 09:07 PM
Zach L's Avatar
Zach L
Thanks, I was wondering about that... would apply to Cayman R models or anyone with lowered suspension I assume too. Are you using a low-pro jack? If so, which brand/model?
BTW, I went over to RideNow on I-35 today to look at some bikes. Considering an MT-07, but they had a Duke 990 that was calling my name. How do you like yours?
Old Feb 21, 2022 | 09:19 PM
Bernie987's Avatar
Bernie987
Although vey different form the Duke, I have the KTM 990 Adventure. I really like it, but I would compare it to Porsche ownership. Just different enough from other bikes to make it need a little more maintenance and specialized fluids. But I do really like that motor.
