I'm going to be installing wheel spacers 7mm front 15mm rears. Anyone done this? I have two sets of the 15mm with bolts 45mm shank length. I've looking for extended bolts for the fronts which would have a shank length 28mm +7 so 35mm with no success. 7mm spacers came today. Asked this question in another forum and got a ton of input without anyone answering the question: For the fronts with a 7mm spacer, are the standard bolts long enough
I don't recommend running 7mm spacer with standard bolts. Either find/buy longer OEM spacers with GT stamped on head (pictured below) or 52mm bolts (37mm length under seat)
