About to change the brake pads anybody have a favorite brake pads spreader
Looking for a brake pads spreader and there seems to be quite a few choices. I saw someone using this one on a GT three seem to work OK any advice that you might have regarding these things?
![Name: photo269.jpg
Size: 503.7 KB](https://rennlist.com/forums/attachments/987-forum/1325972d1639237859-about-to-change-the-brake-pads-anybody-have-a-favorite-brake-pads-spreader-photo269.jpg)
I use a spreader like the above. Just go slow. You're pushing hydraulic fluid back through the system. It'll go, just needs a little time. If you go slow, this has always worked for me. I may take a few mins to actually work pistons back into the caliper. I don't bleed them to do so, but suppose that could work too.
That said, I'm about to replace my front brake pads again, after 45k miles (OEM pads). I ordered the anti-vibration pads, the ones with the little pots that fit into the brake pistons. What I cannot remember is if these vibration bits can be replaced with the caliper in situ (calipers bolted in, rotors in place, sliding stuff in / out of the space after pressing caliper pistons all the way back).
Mine is early 2005 Boxster S, so has the 986 style calipers. Anyone recall if there is enough room? Else, I'll need to acquire the caliper bolts (one-time use and replace if removing calipers).
Thanks in advance.
Thanks in advance.
I do pads 5-6 time a year... never used a spreader.
Spreader is one of those single use tools that does nothing but clutter up the tool box. Now if you are doing HOT/timed brake changes on pit lane, then a spreader may be beneficial.
Just use your fingers to get the initial mm or so.
If you have spiders on the backing plate, use a paint scraper to separate them
Pull one pad out by hand (only remove one at at a time).
Turn the pad 90 deg and use it to gently push the piston the rest of the way in. You want to make sure you are pushing the piston in squarely.
Pop the old spiders out, and put new ones in
Slide in the new pad;
Rinse lather repeat 8 times.
Anthonyr105 (12-14-2021)
I'm a heathen, and use a C clamp. Might buy a similar tool some day just for fun.
The following 3 users liked this post by Robert Nixon:
I open the bleed valves, why push the worst of the fluid back up in to the system? Oh and it doesnt really affect teh system when you open the bleeds and push the pads back, long as you don't leave the bleed screws open..
What can I say, I'm a neanderthal. Pry bar between the ears works every time. Unless you have the reservoir overfilled, you will not push enough fluid to overflow...put a rag around it if you want (I do).
Thanks in advance.
Thanks in advance.
Basic Sponsor
Here's a short video changing the pads on a 987.2 which is the same as all Boxster/Cayman from 97-12. I wish Porsche would have continued making the calipers the same way for the later cars. The 986-987.2 and 996 calipers are so easy to change pads!
--Aaron
--Aaron
