Hey there, I've read about a zillion threads and ended up confusing myself even more. I have a new (to me) 2009 Boxster base with Bose, CDR30 and an aux input in the console. It does not have Bluetooth or PCM. I'm wanting to have hands free phone capability...there are phone buttons on the CDR30 so I'm hoping to utilize those, but will go another route if necessary. And I looking at one of the Tranzit blue FM things?
Just installed the Tranzit Blu on my 987.1 and it's far exceeded my expectations. You may have another options since you've got a .2, but this is probably the cheapest route. $100 and an hour or two of time to install and you'll have handsfree calling and streaming bluetooth audio. The audio quality is very good (much better than a typical FM transmitter). I'm a musician and audio engineer, so I'd like to think my ears are fairly well trained
Thank you, sir. Did I read it can be plugged into the aux input? Would that make taking the headunit out unnecessary?
If you're just looking for an aux-input device, there are plenty of bluetooth to aux adapters out there. I used to use one from Belkin and then another from some knockoff in my previous cars. Worked great, and eliminated the need to pull the head unit. Cheap too... here's a new version of what I had before: https://smile.amazon.com/dp/B01MSUWCZ0
I tried an FM transmitter in the past as well... I hated that thing because living near cities (Boston at the time) meant there wasn't much clear-FM space for it to work with. The aux-version was excellent and eliminated this issue.
Appreciate it. Can I use this thing to make/receive phone calls hands free? If so, that would be perfect (and cheap).
I don't know about "making" as this may depend on the phone. As I recall, you can press a button (this one says press and hold) and then you can use voice commands. So you could use that to voice-command a call?
I only used mine for music and talking on the phone, and my device worked great for that. My phone was usually on the dash anyway, so I could make/accept calls that way without issue.
