Tarett thrust bushing— shouldn’t they need a press?
Old Apr 25, 2021 | 04:41 PM
heybluez's Avatar
heybluez
6th Gear
Default Tarett thrust bushing— shouldn’t they need a press?
I assume a bushing needs to be pressed but these slide in...
so either a. I’m an idiot and it slides in, b. I got the wrong bushing or c. my lca is not OEM
which is it?!
Old Apr 25, 2021 | 05:56 PM
9eight7's Avatar
9eight7
Your LCA looks like it is OEM but your Target thrust bushing is styled like OEM (only 1 hole in the middle), however the OEM thrust bushing is rubber. Here’s an example of an OEM LCA with bushings. Aluminum bushings slip in easily and are 2 pieces, one for top and bottom of the LCA.
Old Apr 25, 2021 | 06:05 PM
heybluez's Avatar
heybluez
6th Gear
Like slip in that easy? No press?
thx!
Old Apr 25, 2021 | 06:10 PM
9eight7's Avatar
9eight7
Yes, they slip in without a press. I have these and there are (2) bolts that hold them together.
