Tire question?
I have stuck with stock sizing on my tires, but I've always wondered if 10mm width makes a difference. It is basically 5mm per side/centered, or .19" on each side. Just can't imagine that is all that noticeable? Translated to height at the same aspect ratio, it is an even smaller difference. Maybe I'm doing the numbers wrong, but seems inconsequential.
If you are looking for track performance, 255 / 285+ is worth looking into (with a lower aspect ratio to keep the overall height consistent).
