Coolant smell after drive
Hello! Quick Question,
I've recently purchased a 2007 Boxster S with around 90,000 miles on it and after I come back from a drive (highway and spirited drives), I would have a lingering coolant smell coming from the engine vent. I do not have any visible leaks nor do I have any sign of a low coolant level. I always check the coolant level before I go on a drive and it pretty much is the same every time. I also got a compression test on the coolant reservoir and the indy shop told me the resulting pressure was fine.
Any ideas on what this smell might be?
Thanks!
Thanks!
Could it be the remnants of a coolant leak that was fixed just before you purchased the car? I recently had a small coolant leak that was fixed by a hose replacement on my 2011 Spyder. That leak was causing a small puddle (about 2” diameter) on the floor after each drive, with a minimal drop in coolant reservoir level. Hose replaced, no more puddling, but I still have a lingering hot antifreeze smell after drives. I’m guessing that trapped antifreeze residue on various surfaces is still *frying* off, and that is what makes the characteristic smell - will keep checking the coolant level for a while.
If you had the system pressure tested and found no leaks, I'd probably be inclined to just try replacing the expansion tank cap. They do wear out eventually and they're not very expensive.
ehokana (12-23-2020)
