987 Wheel Question
Hi everyone, new owner to a 2011 987.2 Cayman base. Currently have the 17" wheels on the car and I'm looking to upgrade to the wheels below.
Can anyone confirm if Titan 7 TS5 wheels (18") spec will fit without any rub with a stock suspension set up? Fronts are 18x9" with a 46mm offset and rears are 18x10" with a 35mm offset. I'd be running probably 245/40's in the front with 275/40's in the rear (open to suggestions though).
I'd like to do coilovers down the road but for now I'll be running stock (height, camber, etc.). Thanks.
https://titan-7.com/products/t-s5-fo...=7537969889308
They'll fit very well, and your tire sizing is good too, especially if you are panning to track the car. Lowering the car would really improve the looks with new wheels.
kt_987 (03-02-2020)
kt_987 (03-02-2020)
My son and I each bought a set of Flow One 18" wheels from Tire Rack along with Hankook RS4s for track use. A set of Flow One's are $1.042. Won't drive them on track until Mar 28-29. He has an 09 BS and I have a 13 BS. I added TPMS to my set, he did not.
kt_987 (03-02-2020)
