PSM Disable switch
Hi all, does anyone have a step by step on how they wired and installed a switch to disable PSM on their 987.1 or 987.2?
I read that it's under the center console. I haven't removed it so I'm not sure what I'm looking for. Also not sure which wire to tap into either.
I figure drilling a little hole and installing a rocker switch under the center armrest would be ok and not intrude into the vehicle at all.
Any input is good! Thanks!!!!
I haven't tracked my car yet. but i do a lot of backroad and twisty stuff. i'm getting real tired of the car applying the rear brakes on tight corner exit.
if the rear is gonna slip, let it slip, i bought p-car, not a prius.
Google search is your friend. Found this with a simple search in an old Rennlist thread Disabling psm completely
I'm late to the party but on a 987.1 find pin #6 on the 6-pin connector of the accelerometer. Install a rocker switch on the #6 wire between the connector and the accelerometer. Turn the rocket switch OFF before starting the engine and PSM is disabled. ABS remains functional.
