987.2 Rod Knock?! Maybe not..... Knock, Knock. Who's there? Valve train? Bore score?
#31
But this is due to driving harder and farther from home and would probably be a bit expensive and overkill for some, especially if you're having the dealer do everything.
#32
A432 your car is certainly well loved ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
The thing about this issue is that getting to the dang thing is NOT easy. You can get the bolts out going thru the front engine cover and from below with that small under tray removed that covers the forward part of the engine.
HOWEVER COMMA: my tech was unable to get the dang thing out without loosening engine mounts and rocking the engine forward slightly to give enough clearance. That adds a bit of complexity to the swap, which I wish was a simple remove and replace through the covers.
Interesting that there are some iterations of this part. Wonder what changed.
#33
