Help...no clutch pedal pressure
Just got my 07 S back from getting clutch PP and fly wheel. I think I can press the clutch pedal with my pinky finger. And when grabbing a gear, the pedal will stick to the floor for a second. Any advice, Thanks
Pump the clutch 5 or 6 times pull it back each time if needed. If the bleed valve is open, fluid will drip below the transmission. An ounce or two. If there is no fluid drip, the clutch was reassembled incorrectly.
So you mentioned nothing about clutch disengagement, so I assume that is working OK. From my minimal experience, no matter what is going on hydraulically, the return spring is supposed to pull the pedal back up (instantly), so I think something funky is going on with the pedal/spring assy. Please post the diagnosis once it is fixed.
Let me be clear, I can't actually push the pedal in with my pinky however, it is very, very light with little effort. Definitely not as it was and not right. And the pedal sticks briefly to the floor at above 6500 rpm shifts.
Update; I dropped it off this morning.
OKay Here Goes
Turns out wrong parts. 2.7 parts in my 3.4.... Mistakes happen
They changed it out this morning and I hope to get it tomorrow. For some reason the A/C compressor is not engaging.
The owners are involved and are nicer than I am at this point.
Cars shifts perfectly A/c fine...
