18" O.Z. Wheels
Old Nov 3, 2019 | 12:59 PM
Martin S.'s Avatar
Martin S.
Default 18" O.Z. Wheels
Re. the 2015 Cayman GTS: Tires for the 20" wheels are somewhat limited in size. I was looking at the offerings from O.Z. on Tire Rack and spotted these:
Front:
  • 18" X 8"
  • 18 X 8 1/2" (Love this combo)
Rear:
  • 18" X 9"
  • 18" X 10" (Love this combo)
I'd love to run a 245 fronts and a 285 rear, even better a 295 rear on 18" wheels, can this be done?
To any that respond, thanks in advance.
Old Nov 3, 2019 | 01:19 PM
A432's Avatar
A432
Hey Martin, you'll like the 245/275-40-18 setup with the NT01's....I also ran 245-35-18 and 295-30-18 R7 on the 987.2 (similar clearances) with the OZ 8.5/10's with plenty of clearance.
The main thing is you want the rears to be about 0.5-1" larger in diameter than the fronts to get the PSM/ABS to play well together (close to stock ratio)
Old Nov 3, 2019 | 01:42 PM
Martin S.'s Avatar
Martin S.
This is great news...."245-35-18 and 295-30-18 R7 on the with the OZ 8.5/10's with plenty of clearance." Of course, the .5 to 1" in diameter is accomplished with tire selection.
245/35/18 Overall dia. 24.4 inches
295/30/18 Overall dia. 25.3 Inches
The above overall dia meets the .5 to 1" delta criterion.
245 and 295 have been good to me in the past. Thanks so much for your speedy response. Wish me luck that my prospective Cayman GTS passes its physical (PPI) on 11/4.
Old Nov 4, 2019 | 03:34 PM
badabing's Avatar
badabing
Check out Apex wheels as well. I bought a set of 18" to use on my 987 during summer on track and as winter wheels on my 981 GTS.
They look really sharp on both cars
Old Nov 5, 2019 | 09:22 AM
monochrom3's Avatar
monochrom3
FWIW, I fit 255 and 285 on a 987.2 with apex wheels. 245/275 on the OZ
Old Nov 6, 2019 | 04:46 PM
txbdan's Avatar
txbdan
Attachment 1310045
What size/offset wheels?
Old Nov 7, 2019 | 12:03 AM
monochrom3's Avatar
monochrom3
18x9 et46 and 18x10 et36
Old Nov 8, 2019 | 10:17 AM
txbdan's Avatar
txbdan
How wide of tires can be fit on a 981?
Is it a no brainer to go for a 9" front wheel over a 8.5" front wheel given proper offsets? Apex and Titan7 offer 9" fronts while the OZs are 8.5". This assumes an appropriate amount of front neg camber for track use. At least -2.0.
Old Nov 8, 2019 | 08:04 PM
duffin's Avatar
duffin
Titan and use OEM.
Tire size calculator with mph difference, etc.
https://tiresize.com/calculator/
