LN Engineering PDK oil water exchanger experience?
Number 1 issue doing spirited driving and tracking on a 981 Cayman is high oil temp and keeping PDK happy.
I am adding the 3rd radiator, but also looking for oil water exchanger solutions to keep PDK temp happy.
I found this LN Engineering PDK cooler.
https://lnengineering.com/987-981-pd...ide-mount.html
Anyone with experience with this cooler or alternative?
Given I may add Soul headers, concerned about clearances as well.
The single greatest way to address the engine oil temperature is to install our 2.5 quart deep sump:
https://lnengineering.com/products/b...1-engines.html
It's been shown to drop oil temps 30-40F.
I'm concerned about the deep sump when I am lowering the car -20mm with a X73 suspension kit.
Will the deep sump clear?
Also should I prioritize deep sump over PDK side-mounted cooler?
We do offer skid plates if you are concerned for extra margin on a street driven car.
As far as prioritizing, an engine is more expensive than the gearbox so I would address high oil temperatures first.
I'd be more concerned about servicing the PDK with fresh fluid and a new filter much more frequently than you would for a street car. When we serviced our GTB1 cars, the PDK fluid got changed every other event, gear side fluid every third, and filter for the PDK every other fluid change. Coupled with the Driven DCT and all the extra cooling, we never had any issues with our fleet of PDK race cars we maintained, when we were focusing on track support.
We ended up coming up with other upgrades, like our billet PDK pan with modular filter, to address the high costs for pan/filter replacement from Porsche. We also developed an axle spacer kit to address issues with PDK axle seals getting damaged.
I know some have had negative experiences with the PDK, but as a whole, we have had great results with the PDK in race use.
Same with the 9A1 engine. It's been bulletproof for us as long as you keep it cool and use good oil (we only run Driven XP9 for engines that see track duty).
Ground clearance has never been an issue with the billet deep sump, even with full race suspensions on our GTB1 builds. I ran one on my 2010 Cayman S with coil overs running GT3RS ride height and never had it bottom out once on the street.
Given this is a 2.7L and I am just trying to keep it healthy and whole driving HWY 1 (every weekend) and Sonoma Raceway and Laguna Seca (4-5x a year) and using it as a street car 1-2x a week, I need to watch the overkill factor.
So, I was thinking with a CSF center radiator install, I'd be lowering oil temp to stay below 250 degrees and change oil frequently (my guy uses Swepco 530).
But I worry about the PDK, thus I was thinking your PDK-side cooler would be an economical insurance plan with the full PDK service I just had.
With my driving profile and the info above, you are recommending the sump AND the PDK-side cooler?
I would certainly do the CSF center (and top exit if you like the look) and PDK cooler, then monitor your coolant and oil temperatures. If you are consistently seeing temperatures over 250F, I'd add the deep sump next. Perhaps your base model runs lower oil temperatures than the S models and for sure, less then a Clubsport or car that has been fitted with a 3.8 - those run the hottest on track.
Don't make too many changes at once or then you won't know which change helped the most.
Vettel-ish (07-09-2019)
I have the 3rd rad (oem on 987S pdk) upgraded to CSF Race, the GT3 smile vent, the BGB air/oil diff cooler and most recently this LN engineering PDK cooler.
I also have Fabspeed race headers installed.
Car is a 2010 Cayman S PDK.
I installed everything myself except the LN cooler. The shop I used never installed one before but said it was straight forward. Charged me 6 hours but I think it should have been 4 or 5.
I don't have a way to monitor temps so can't really say what the difference is lol.
I'm faster on track because my wallet is lighter.
kcirderf (10-02-2020)
Charles,
What do you think about badabing's install of 6 hours? Seems to only need 3-4 hours of install?
What PDF fluid do you recommend for street/track?
Link to the billet PDK pan with modular filter?
Can you comment more on the axle spacer kit to address issues with PDK axle seals getting damaged?
Ordered the CSF and PDK cooler. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Charles,
Charles,
Here is the billet PDK pan. It also increases the fill by about half a quart:
https://lnengineering.com/products/b...ssion-pan.html
As far as the axle spacer, the description on the store explains it best:
This axle spacer kit alleviates the added stresses put onto the axle with the additional camber and track width that comes with race alignment adjustments. The output shaft, that is only help in by a wire clip, will pull out of the transmission. This can tear the seal causing intermix of the PDK and gear fluid, and also disengage the differential. This can cause serious damage on track.
https://lnengineering.com/products/b...pacer-kit.html
As far as hours, I'm not sure. I don't do any of the estimating for the race shop side of the house. You're welcome to call LN and speak to my technician, Andy. He handles most of the requests for support at LN. Just give him a call at 815-472-2939 and I'm sure he'd be happy to review any and all of your questions about the upgrades.
We use the Driven DCT for both street and track. I've run it in VW DSG boxes as well with zero issues in my GTI and Macan.
For the oil pan, it's not until Porsche went to a plastic engine oil sump pan that they slightly changed the design, which we have a replacement billet deep sump for that application in development currently.
They are also compatible with the 981/991. No problem there.
What PDK trans fluid do you recommend running for street/track?
We use Driven DCT in our shop for all PDK/DSG services:
https://lnengineering.com/driven-dct...d-1-quart.html
Yes, both would be compatible with your 2015.
