DME Question - Invalid??
Personally Id walk, too many cars out there without track time. Did he do enough track time to set the stage for the noted 3rd gear failure ?
did he hit a larger berm, hole, etc. leading to an inevitable strut tower failure ? ( that sounds like fun).
i will never assume a prior owner cared for something the way Id like to believe I would .
I'd rather have a well maintained car that's been tracked than a car serviced minimally by a careless non-enthusiast owner. Anyone who is going to track the car regularly should be on top of maintenance, fluid changes, replacing wear items preventatively, etc. It's the cars I track that I have been most fanatical about maintaining because even little things you might put off on a street car could become safety issues on the track.
As far as I can tell, there are no issues with these cars that arise from track use other than increased wear on consumables (bushings, bearings, shocks, brakes, etc). I would take any ppi details around wear on consumables into account for pricing but track use in itself wouldn't bother me. The dme report wouldn't bother me either but I would want a leak down/compression test with level 5/6 overrevs to validate there was no engine damage.
I don't disagree that a well-maintained tracked car can be a good deal if the price is right and you take into account the issues listed above by several contributors. And of course a poorly maintained car, tracked or not, would not be a good choice. However, having read countless threads on issues that arise on the track, or things to do to get your car ready for the track, I (personally) will continue to shy away from any car that has had extensive track time due to the increased risk of having issues. I spent over 40 years in product development, much of it in reliability engineering, and nothing in that experience taught me that increased stress reduces failure rate.
Thanks for all the replies. Very helpful.
Ultimately Ive decided to walk away from the vehicle since I couldnt get a clear picture on the extent of its track usage.
Thanks again!
Thanks again!
