Wheel question
Porsche offered several wheel options for these cars, which wheel do you have?
I believe the lightest OEM 19" wheel Porsche ever made for a production car was the 987 Boxster Spyder / Cayman R wheels
19x8.5 @ 21.4 lbs
19x10 @ 23.4 lbs
19x8.5 @ 21.4 lbs
19x10 @ 23.4 lbs
I haven't put them on the scale, but my arms tell me that my OEM 20" Carrera S wheels with OEM 235/265 PZero's are lighter than my 19" (1/2" wider) HRE FF01's wrapped in 235/265 RE-71R's. I will be swapping wheels in a couple weeks when the weather finally gets warm and stays warm. I'll try to put them on a scale at that time. I believe Tirerack publishes approximate weights for tires, so those can be subtracted from totals to get approximate wheel weights.
Tire weights:
PZero 235/35R20 = 22lbs, 265/35R20 = 28lbs
RE-71R 235/40R19 = 24lbs, 265/40R19 = 28lbs
Tire weights:
The Spyder wheels were the lightest made for the 987 but I do believe there are one or two aftermarket wheels which may be lighter. I thought OZ made a lighter wheel also?
Scooby brings up a great point about the tires, I’ve found that Pirelli and Michelin are the lightest tires on the market by at least 2 - 4 lbs a tire. Bridgestones are much heavier as are some of the other brands. I believe some of the Continentals are also lighter but they seem to lack the performance of the Michelin and Pirelli.
Volk TE37 in 18 are < 20 lbs front and just over 20 rears. They are excellent forged wheels. Hard to find though.
The 987 Spyder/CR wheels were the lightest 19" OEM road wheel Porsche has made. Lighter than many of Porsche's 18" wheels, but there are lower-diameter OEM wheels that are lighter. For the combination of looks and performance for the street, the BS/CR wheels are the pinnacle. I use those for the street and the OZ Alleggeritas for my track setup.
If I remember correctly my 20" FF-01's were 3-4lbs lighter a piece that my stock Carrera S wheels. BTW, here is a great thread comparing various wheels and their weight
https://www.bimmerboost.com/showthre...8-20-inch-rims
Strength is the variable never considered. Forged is only stronger pound per pound. Ideally what you want is high strength, light weight, and low cost if able. That probably best describes OEM wheels. Happy to have less weight, but if it results in a more fragile wheel then no thanks. And since there are no tests to prove strength I just stay away from aftermarket. But also I typically buy the cars in which Porsche puts their efforts toward real weight savings, ie, Cayman R, Spyders, and GT4. I'd rather Porsche do all the engineering.
"Paint" your wheel? My avatar shows my 911 with the stock wheel. sometime after that pic, I decided I wanted a 930 wheel, and ordered one in black. My car has a medium/dark blue interior. I found a guy who refurbishes interiors at used car lots. 5 years ago he 'painted' my 930 wheel to match interior. It still matches. (He made me very scared of used cars. I looked at a Volvo convertible he had worked on. One seat looked new, while the other made me want to puke.)
My reference to Porsche wheels wasn't an assertion they manufacture the wheels. The BBS plant in Germany wasn't terribly far from my house. It mostly made wheels for car makers, so I'm well aware of how this process works. BBS wouldn't survive as a company if they didn't. In fact, they almost went out of business in 2009. I've had many OEM wheels made by BBS, as well as BBS "proper" wheels. I do appreciate their manufacturing and quality standards. In the end, I'm more than satisfied with OEM wheels as they are "period correct" and I like that, and I don't find wheels made for a multitude of different cars aesthetically appealing. When I had a Cayman R and 2011 Spyder (simultaneously), both had Spyder wheels and I would have never thought any other wheel could look as correct on those cars.
