There isn't a hard and fast rule, but I'd get one if you don't drive it at least once a week for 20+ minutes. They're inexpensive and make the battery last longer.
Thanks. I certainly intend to use the car once per week and drive over 30 minutes, but I wasn't sure if these cars had batteries with quirks. I don't have access to power where I park, so it make things difficult to run external power.
If you haven't already, familiarize yourself with the procedure on how to open your frunk to gain access to the battery should you need a jump start. I'm not sure if it's the same on the 981 as the 987, but if it is you'll want to know the procedure as there is no manual frunk release lever like most cars have.
I leave the frunk unlatched on all my cars. Just in case.
I've learned with other collector cars that if you don't drive it regularly it's bad for the battery. Sitting idle for a couple of weeks at a time will eventually shorten the life of the battery. I keep battery tenders on all my classic cars and my 981. Even though I drive the Boxster fairly often, sometimes it sits for a week or two. Good insurance for keeping the battery in good shape for many years of service.
