Replacement of CDR24 on 2007 987 Boxster S
Apparently my CDR24 stereo unit is not putting out a fiber optic signal and that is why I am getting no sound out of the speakers. My dealer tells me that each radio is specific to the VIN of the vehicle and thus I can't reprogram another CDR24 from a parted out car. Does that sound right? I thought Dealers could program whatever code was necessary. If the dealer is right, I don't know how Porsche could ever fix a unit broken in any car if they can't be replaced. Any help would be appreciated.
Thanks,
Gil
Thanks,
Gil
I would be really surprised if that was true considering there is a market for replacement (new and used) CDR-24's, should only require reprogramming to get everything working. Alternatively you could replace it with an aftermarket unit, though there's a bit that goes into integrating it with the Bose system.
As to replacement with aftermarket components, the complexity depends on how much of the existing components you want to use. If you have a Bose equipped setup and want to continue to use the amp and speakers, the process is more complex (especially with the fiber optics). I you gut all the original equipment you don't have to worry about compatibility with the original components.
Gil
