buying advice 2009 987 Boxster
Old 08-03-2018, 07:01 PM
grgallo
grgallo's Avatar
Default buying advice 2009 987 Boxster
RListers, I'm looking at 2009 987 PDK Boxsters and would like advice on what to look for regarding a PPI. Oil leaks? rear main seal? Convertible top issues?, PDK issues? What should the mechanic look for? Also, the car has run flat tires and I was told that is original equipment (these are new) but I can't confirm Porsche put run flats on these cars? I'm told run flats are to be avoided. And the car has an aftermarket touch screen head unit, Eclipse brand. Not a fan, doesn't play CDs. What options do I have regarding head units. The car has Bose speakers. Thanks in advance for your help.
Old 08-03-2018, 07:33 PM
ekam
ekam's Avatar
PPI should examine all those items mentioned.
Runflats are junk.
Old 08-06-2018, 11:55 PM
my04996tt
my04996tt's Avatar
I had an 08 booster s and a 12 black edition s, had absolutely no issues with either of them. Both were manuals, the Michelin’s weren’t run flats. They were both excellent cars,
Old 08-07-2018, 07:53 PM
grgallo
grgallo's Avatar
thank you gentlemen, did Porsche put run flats on the 2009 Boxster? Either standard or as an option? I find that difficult to believe.
Old 08-07-2018, 10:25 PM
my04996tt
my04996tt's Avatar
Both of mine had OEM Pilot Sports/2. No run flats.
Old 08-08-2018, 03:23 PM
daylorb
daylorb's Avatar
Find a good PPI - that is the key. They will look for all of these things. In general there are very few widespread issues with the 987.2's. As for run-flats, no that does not sound OE, but they are tires so not a huge deal - I'm guessing someone at some point felt the need to use them. On the head unit, you could certainly switch back to OEM, there are all sorts of options available on ebay, or any local stereo shop can swap in what should be a double-din unit. If it were me, I'd consider going back to stock although you'll lose at least some bluetooth functionality.
Old 08-08-2018, 03:40 PM
SpyderSenseOC
SpyderSenseOC's Avatar
Received 1,347 Likes on 808 Posts
My understanding is that run flats were required in all cars that do not provide spare tires, including space-savers. Not sure whether 987's had spares or not.
Old 08-08-2018, 03:43 PM
66mustang
66mustang's Avatar
They do not have spares, and do not get run flats.
we get a bottle of goop and a tire inflator
Old 08-08-2018, 04:40 PM
SpyderSenseOC
Oh man. That's sad.
Old 08-08-2018, 04:44 PM
ekam
ekam's Avatar
Porsche does sell spare tire kits for 981 & 987.
https://www.suncoastparts.com/product/PK981SPARE.html
https://www.suncoastparts.com/product/987STK.html
Old 08-08-2018, 04:46 PM
Marine Blue
Marine Blue's Avatar
Oh man. That's sad.
I was under the impression that Porsche went to the goop and inflator for all of their sports cars since 2005 although the Cayenne may be the exception.
Your Spyder should have the same also.
It’s a weight and space saving measure.
Old 08-08-2018, 05:42 PM
SpyderSenseOC
You're probably right. I'm going to have to open that frunk one day and look in there.
Old 08-08-2018, 07:10 PM
grgallo
grgallo's Avatar
thank you RL folks, I knew I'd find an answer. Yes, the car had no spare and the car had RFs so a previous owner decided to go that route. so, if I pursue this car I'd replace the tires, get a spare tire kit and go back to OEM head unit.
Old 08-08-2018, 07:50 PM
Marine Blue
Another option is to get the goop and compressor (if its missing) and sign up for AAA to handle any catastrophic failures.
Old 08-08-2018, 09:39 PM
tomhartzell
tomhartzell's Avatar
Suncoast (no affiliation) offers a spare for the Boxster. https://www.suncoastparts.com/product/987STK.html
Not cheap, but you won't have to wait to have your Boxster towed anywhere. I bought mine off eBay for $400 from someone who had sold their Cayman. Going to Rennsport in Sept, and don't want a tire problem costing me a day or more.
Quick Reply: buying advice 2009 987 Boxster
