Had to order an Optima redtop since the OEM-looking battery is of unknown age. Should have it installed by next week and I can do a ROM dump and get this Cobb AP thing sorted hopefully...
Drove home from work for the first time with the plenum installed, there's definitely better throttle response starting around 3-4k even without a tune. Engine revs a tad bit faster.
Again, this is just my butt dyno and your result may vary.
Spoke to Greg @ IPD. He said 99.9% of the time it's the 2 hose clamps between the TB and MAF sensor that came loose after driving. He said, touch it, feel it, check with a mirror from underneath to make sure it's 100% secure.
The check engine light turned off after I put a tank of gas in this morning. They double checked all the connections along with going for a long test drive to ensure nothing came loose. They suspect the plenum didn't get a proper seal from the manifolds.
