Making the wife happy!
It's honestly just a pretty loud car. Nothing wrong with that to me, but it is the most common gripe from journalists and such for the last 10 years. Michelins would probably be somewhat quieter, but it is not going to make it sound like an E Class (nothing).
Install sport exhaust and open valves to drown out tire noise with glorious exhaust notes?
I can't say I have tire noise issues with the Cayman. Porsche did a poor enough job directing air flow around the side mirror and windows that I get wind noise and buffeting more than I get tire noise.
It is the tires. Sell the P-zero's and get something else. I haven't heard from many folks that like them in the first place, and they are known to be loud. I have PS4's on my Spyder and don't find them bad at all, but if quiet is more important than ultra high performance, check out this list: https://www.quiethomelab.com/best-quiet-tires/
I have Pirelli PZero from the factory on my 2016 Spyder and find that the tires themselves run surprisingly quiet if the pavement is fairly smooth asphalt. Move onto concrete or old asphalt and road noise picks up substantially to the point where conversation is challenged. I attribute this less to the tires and more to Porsche's inability or unwillingness to add more weight and rubber to damp down NVH: noise, vibration, harshness. So basically the noise problem lies more with the chassis than with the tires as far as I'm concerned. Having said that, I suppose it's more than possible that the new Michelin 4S will run quieter over rough pavement than the Pirellis but I doubt whether the difference will be sufficient to make your spouse happier. But it's probably less expensive to change the tires than it is to change the spouse (or the car), so good luck in your endeavor! LOL
I have the PS4S on 19's on mine and they seem fine. Prior PS2's were fine too.
You gotta fix the issue. My wife got to the point of refusing to ride in the 968. 'Course this was after it became a spherical bearing, 10x spring rate, climb-over-the-cage, beast. Couldn't even convince her to make short summer evening ice cream runs anymore. #sad
Don't be like Dave. Don't let your car become disliked by your spouse. It helps nothing.
The Boxster S? No issues. She'll take it to work and on trips every chance she gets. Happiness is...
Dave
'05 987S
'92 968 SP3
'88 944 NA (gone)
Dave
'05 987S
'92 968 SP3
'88 944 NA (gone)
Buy an S550. Pretty quiet.
Joke, sorta. I loved both my Boxsters but my wife thought they were “too small”. So I traded my ‘16 GTS on my current Targa and she didn’t complain at all during 1300 miles back and forth to Asheville last Fall. But the Benz has massaging seats...
I found that the interior was slightly loud when i got my car. I put some dynamat-type materials around the engine bay, in the trunk, and also on the wheel well liners (on the side facing car, not the tire). I forgot to measure the noise level before this work (only have it post-work), but it helped to quiet down the car a bit. There is still tire roar on certain types of pavement, as someone else mentioned, but it may help.
