Fault Cooling System reset
Hi,
I have the 'Fault Cooling System Visit Garage' yellow message on my 2013 981S :-(
Does this fault need to be cleared by dealer or will the warning go away if the fault is fixed - i.e. if I find it's a vaccum hose that is loose and reseal it will the warning go away if that was the issue? or does the warning stay until reset by the diagnostic port.
Also, apart from the much discussed PSE vacuum hoses are there other things I should check?
From: On a pygmy pony over by the dental floss bush
Hi,
