I don't have any input but I'm new here and trying to learn. "Over rev report" I assume that means the number of times or length of time spend in the red or somewhere over a "safe" red? I see your highlighted numbers but don't fully understand the terminology with them.
I'm buying a Cayman soon and am trying to understand what to look for in one of these inspections.
Strange to see over-revs in range #4 and #5 without operating hours also registered.
Does the car have a tune? Was the DME-ECU wiped?
I'd proceed with caution.
-10,725 mi
-The total hours are not listed in the report. Not sure why.
-Not sure if its tuned. It's at the dealership a few states away. I did not know you could wipe the ECU?
-10,725 mi
It's CPO'ed so it should be ok???
CPO helps a ton.
I'd want to know the total op hours. Easy for them to tell you. Ask.
Also ask them why no time stamps in range 3 and 4?
Also ask them how Porsche can CPO the car with over revs in range 3 and 4.
Yeah, I too am surprised it can be CPO'd with those over-revs. On the Durametric site they talk about people trying to reset and hide things, but only some of the things get reset. They mention looking at various timestamps/averages to see if they are consistent and make sense. I wonder if someone tried a "reset" to hide the overrevs, but only the time not the count got reset. Just a wild guess, but you should get answers.
So on this report it shows 17 ignitions in Overspeed Range 3 - does this mean that the engine went almost 3 cycles (intake, compression, ignition, exhaust) across all cylinders? 3 complete cycles of 6 cylinders being 18 ignitions. If so, at that speed it wasn't there very long!
And the last occurred at 80.31 total hours on the engine?
I talked to the technician that did the CPO and he talked to Porsche about it. They said if the hours did not populate that is is a false positive. I am waiting for him to get me the total hours so I can verify the mileage to make sure there is no funny business going on. If it all checks out I am going to buy it
Yea, here is the calculation for the amount of time spent in a range, taken from the link above:
Number of ignitions / 3 = number of engine revolutions
Number of revolutions / by rev limiter = minutes spent at limiter
Minutes spent at limiter x 60 = seconds spent at limiter.
