Thickest Wheel Spacers for 987 Boxster S?
Former Vendor
We've got H&R springs on our 996 and I really like the stance. The quality is also second to none.
Former Vendor
The 981 springs will work with PASM and PDK. They don't lower the car a full inch because you're already starting out a little lower than a non-PASM car, but there are no issues with using them on a PASM car.
Just an FYI. Although the look is much better with running for example a 5-7mm front and 15-20mm rear spacer you are actually inducing understeer. (your actually adding more to the stock mild understeer already set from factory. For better handling on stock tires size or (proportions sizes equal to stock ) the set up you actually want is 5-7mm wider in the front. So for best handling add a 5-7mm upfront and nothing on the rear. Handling or looks its a trade off. There are ways to get both. Simplest is to run a wider tire up front 255-265 no spacer. There are many ways with after market suspensions to correct too.
SBD, what do you think of Gary's idea? I can't say that I've really noticed that I've introduced more understeer and maybe I'd only notice in extreme cases such as on a track? Then again, I come from SAABs, cars known for their extreme understeer...
Proper alignment - not going to help the push. The standard track autox set up is max camber up front (about .75 average) then add plus one degree (1.75) at rear. Then zero toe front and rear with slight toe out to get a light rotation help. Some folks like a slight toe out for autox too. Max front castor In addition, you should have your alignment checked as the cars vary from the factory and the cars are quite sensitive to alignment settings.
Anyone have experience with the $139 7mm spacer kit from Suncoast? http://www.suncoastparts.com/product/SPA7MM.html
