New garage for a spyder
#61
That is one beautiful garage,Joe! Congrats
#63
Ok - need some advice on this topic. I am on the second design of a detached garage to meet county and HOA provisions. The latest version and site plan are fully compliant with the County (including the addition of a ridiculous retention pond for runoff). The dimensions are 36x40, and now the HOA is saying it's too big (from heavy lobbying from neighbor). It is planned to be a compliant 30' from the side setbacks on a heavily wooded 3 acre lot.
I am considering next step which would likely require a formal legal process. My question is based on what I could find from case law. The courts seem to find for HOA only when the Covenant are specific. More often the courts find for the homeowner due to the HOA's "exceeding their jurisdiction as set forth in the Covenants".
Has anyone been in a similar situation? Hope this isn't if it is, I will repost.
#64
GT3 player par excellence
1600 sf over a 3 acre lot (130k+ sf), i would shoot the neighbor.if they can see your garage at all, they are peeping toms.
if HOA doesn't specifically disallow it, and you are within floor area ratio of city general plan, your neighbor really has little legal rights. u can call it a living room or in law unit. i park my cars in the living room. really. it was a fire station. the fire engines used to park in my living room.
there is no law preventing you from parking cars in your living room. no need to call it a garage.
#66
I've been doing my fair share of research on lifts for my new house, so I'm familiar that many of the four posts can be run safely without being anchored.
However, I was suspicious that the load being focused on the tile could be an issue, good to hear that it's not! How have the tile been holding up? Any issues with fluids? E.g. does it get overly slick or stain from them?
#67
sorry for delay, thanks for the info! I've been doing my fair share of research on lifts for my new house, so I'm familiar that many of the four posts can be run safely without being anchored. However, I was suspicious that the load being focused on the tile could be an issue, good to hear that it's not! How have the tile been holding up? Any issues with fluids? E.g. does it get overly slick or stain from them?
Water from the a/c condenser doesn't stain. Oil dropped on the ground for several days doesn't stain. Wipes off like nothing.
PEI grade 5 porcelain tile.
#68
awesome to hear, you've convinced me, i'm shopping for tile for the new house. thanks for all the info!
#69
Joe - how wide is this garage?
I am looking at a 21ft wide by 23 ft wide by 10 ft tall garage and trying to decide whether to center mount the 4 post or put it on one side. Gets a little tight on the side of the lift next to wall if not centered. Want to be able to comfortably work on the side of car (swap suspension etc)
Thoughts?
Thoughts?
#70
i like the garage , but i am curious about your opinion on the brz. I owned one for 6 months, which is not unusual for me, it felt underpowered but otherwise great car. I think engine is over rated at 200 hp and 135 tq.
#73
Woah, talk about reviving a dead thread. Sorry, I rarely check in this area anymore.
width of the garage isn't important in this case. You want to know how much space there is on the side garage slot between the opening of the garage and the wall. Best thing to do is find out the exact measurements of the lift you are are looking at and mark it out to see if there is enough room. I have 17" between the wall and the opening of the garage. That just barely gives me enough space to work on the side of the car.
Fun car, but it didn't hold up to track use. Literally would fall apart. I had to retire it from track use and only used it as a DD. Then I sold it after I ended up with an electric car for a commuter.
Thanks. No heat/AC. Haven't needed it yet here in Cali.
Thoughts?
Thoughts?
#75
I'm not thrilled with my atlas model. It makes a lot of noise and the rolling jacks are not low profile. I have the 408-SL, but my buddy has the pro8000 which is quiet and has low profile jacks. I would go with the pro8000 next time.
