1:41 laptime @ Laguna Seca in the spyder
Figure out if that stable energies harness bar fits on our cars!
Thanks! Would be great to get 3 more days out of them. Will follow up with more pics after the next track day
You are fast. The fact that you are eating out the outsides of your nittos while still having decent neg camber also confirms your high pace. You're playing with your life (literally) if you're driving HANS-less. Not a joke.
Why do you need a harness bar in a 987 Boxster?
I have the stainless steel version of the Remus, not titanium.
You should keep in mind that the sound in the video is NOT what the car sounds like in real life. It's actually kind of underwhelming in real life, which is why it passes the 90dB limit. The mic was placed right behind the license plate, so it makes the car sound much meaner.
About 2 years ago, we used a decibel meter to measure the exhaust noises from different systems. Someone correct me if I'm wrong, but this is what I remember:
Stock: 88dB
Oem sport exhaust: 88dB. Yes. The same peak.
Remus: 92dB
Tubi: 94dB
My thoughts on the Remus are that it sounds more aggressive in the low range without drone, but at the peak it is about the same as stock. Tubi really does sound the best, IMO, and still has no drone. But, it won't pass sound at Laguna.
Stock: 88dB
Remus: 92dB
Tubi: 94dB
If you want great sound (most likely will knot get by at Leguna) is my 3.8 GT3 with the Sharkwerks center by pass
It may be the angle of the pics but your right tires (especially the front one) are worn more than the left. I don't know if the other tracks were also counter-clockwise but consider switching your wheels from one side to the other after each track day. Once nittos get worn, I've also seen people flipping them on the wheels (inside/outside) to extract few more days out of them.
Seriously, though, I appreciate your concern. This brings up an issue that I have been struggling with for a while. The problem is the mounting points for the shoulder straps on the 987 boxster. They are too high. For them to be properly mounted, it should be at my shoulder level or a touch lower. They actually sit higher than my shoulder currently. There was a thread a while back that discussed this. Redyps did some research on this and discovered that a HANS won't work properly if the shoulder straps are mounted too high. For this reason, I haven't pulled the trigger on getting one. I was planning on getting one for the 991GT3 when it comes in, but the lack of sport buckets and a clubsport cage for the US version will only delay my ability to use a HANS in that car as well. This is why I am interested in seeing if something can be done to fit the stable energies harness bar in the spyder.
No doubt your GT3 sounds worlds better. I'm tempted to do the bypass on the 991GT3 as well. It will take some custom work to get the car to pass 90dB... what a travesty MRLS is becoming...
Couldn't tell from the video. Someone else in the thread mentioned it.
I wasn't aware of this. Someone else mentioned it in another thread a while ago and didn't get back to me after asking about it. I tracked my (now gone) 987S Boxster for six years using Euro 6GT3 seats, HANS, and harnesses strapped to the OEM bar behind the seats. Have seen many others do it, too. Race shop owners/mechanics I know never mentioned anything about it, either. My HANS felt pretty solid once harnesses were pulled tight. Do you have links for these discussions?
I believe all 986/987 race Boxsters (Spec, and others) use the OEM bar for harnesses -- or am I wrong?
Former Vendor
How do you guys know I'm not using a HANS from the video?
We recently sent out one of our bolt on harness bars to a customer with a Boxster Spyder and it would not fit properly due to the hump in the upper portion of the firewall that protrudes into the interior. Regular 986 and 987 boxsters don't have this, and installation in those cars is a breeze, as long as the car does not have the premium sound system, which can be removed very easily.
We are currently trying to figure out what would need to be done to get the bar to fit, or if the bar can be modified to fit.
If their are any Boxster Spyder owners that are local to us and wouldn't mind bring their car to our shop for a little R&D, please contact us.
I'll pay a visit to wine country motorsports in the new few weeks and try things out.
This is correct about the shoulder belt height in the boxster. The cross bar for the stock roll hoops in the boxster is too high for the majority of people, probably for anyone that would actually fit in the car!
Found the post from redyps that talks about the problems with using a Hans with the stock roll bar:
https://rennlist.com/forums/9401125-post36.html
I spoke at length with the guys at Schroth about shoulder belt positions and HANS. They stated that if the shoulder belts were NOT mounted between 0-20 degrees below the shoulders (with a clear pass through the seat backs) or had a guide bar below the shoulders with a floor mount point a HANS would actually exacerbate the problem. They put over 3 months into engineering of any potential change e.g., a harness cross bar (which requires a 6,000 lb load) so I have confidence that what products they offer and what advice they provide is well founded...
Donn
Thanks. I vaguely remember that the harness points may have been only slightly above my shoulders but my body and the HANS were held rock solid by the shoulder straps. No problems with the helmet being under the roll hoops either. Must have been a sweet-spot. But from your other video I can see how the harness points are way to high for you -- hard to even keep your body strapped in, much less a hans.
I can't speak to HANS compatibility since I haven't used one with stock 987 roll bars and harnesses. Instead, I wear a thick firm foam neck collar on the track. These are often looked down upon as not providing much/enough protection, but I can't move less than an inch in any direction (360) and they at least provide sideways protection unlike HANS.
