Rodent problem
Rodent problem
Today, while driving my Cayman, I noticed some tiny black debris around the HVAC vent at the base of the windshield. It was one of those "H-m-m-m-m-m" moments, but I went on to my destination, parked and locked my car. Was in the store probably 10 minutes and came out to flashing lights and the alarm going off in an otherwise empty parking lot.
I shut the alarm off, walked around the car and seeing no damage, got in and drove off. A couple of minutes later, I was sitting in slow traffic with one hand on the wheel and the other resting on the console when I felt something on my hand....Looked down and there was a mouse sitting on my hand. Of course, in the subsequent spasmodic freak-out, I jerked my hand and the mouse fell on the floor and scurried under the seat.
When I got home, I examined the black debris on the dash. It was tiny pieces of black plastic that had apparently been blown out of the ducts when I turned on the defrost/defogger to clear the windshield. I then went into the frunk and removed the cover over the battery. The area under the battery was filled with seeds and house insulation, probably a pound or so. Clearly the little bastard had set up house keeping in there and then gnawed his way into the car (Hence the black plastic bits blowing out of the ducts).
I've vacuumed and blown most of the seed/insulation crud out from under the battery area, but I can't get it all out without some major disassembly. More concerning is that there is apparently a mouse-sized hole somewhere under the dash or ducts. I've found no plastic bits under the dash and none under where the car is parked.
Any advice on where/how I should be looking for damage?
TIA
Terry
TIA
Terry
Agreed, get a dealer or tech to take a look. You might need to report it to your insurance depending on the extent of the damage and cost to repair.
firstly, i had a rodent chew some wires on an Audi and cost my insurance company $4 for a new harness. Them rodents love wire as the wire shrouds are make from a soy base. after that incident i now sprinkle cayenne pepper powder around the engine compartment. so far so good. Also, even if you car is garaged make sure all ingress is sealed with no food, like dog food, stored in the garage.
If you have a garage there are small plug in ultrasonic devices that supposedly repell rodents. I have four of them arranged in various wall outlets. I also lay down sticky traps near the garage doors during winter storage just in case any of the little rascals decide to come inside.
I've used this stuff called "Victor Scent Away" from Home Depot for ~$8. Seemed to work well.
They're small mint scented packets (trying to post a pic..)
Were you able to determine how the mouse got into the frunk to begin with?
And once in the frunk, did the critter eat his way through the cabin air pre-filter to enter the hvac ducts to get into the cabin?
Just put my 981 into winter hibernation for the first time...thinking about preventive measures.....any advice welcome.
Oh I feel for you!!! Those little bastards are EVIL....I have had them in all my daily drivers except my Porsches which are in a varmint proof garage (so far)
Barncat. We have one in the block where the car garage is. I do have to scoop up remains left outside a door from time to time. I know which cat it is and give it a treat when I see it.
If you do use bait put it outside in a place where only mice can get to get, you do not want to train mice to come inside to eat.
Were you able to determine how the mouse got into the frunk to begin with? And once in the frunk, did the critter eat his way through the cabin air pre-filter to enter the hvac ducts to get into the cabin? Just put my 981 into winter hibernation for the first time...thinking about preventive measures.....any advice welcome.
I wish I could advise you on preventative measures, but we've been parking cars in our garage for 25+ years and have never had a problem with mice. This is all new to me....
Newer cars have soy and other plant based plastic coatings on wires which become a food source for mice, unfortunately it means we need to be more diligent with our pest management. I make a point to walk around the garage regularly in search of mice droppings and other hints of rodents.
