Recommendation for replacement rotors and pads
Any recommendations for aftermarket rotors and pads for a stock 2009 Cayman -- I would like to have my local garage replace them but need to supply the parts -- any tips on quality or price are welcome -- just drive it occasionally - it is not a track car!
Do a search on this forum for brake disc recommendations. There are several aftermarket brands that are good and are much cheaper. Sebro and Zimmerman are considered good brands and are available from Pelican and other dealers. Consensus is to avoid cross-drilled rotors (like the OEM) and go for solid or slotted.
As to pads, I've been a Hawk fan for several years on various makes of cars, but again the consensus for a non tracked car seems to be Porsche OEM or Textar (as I understand, an OEM supplier). I have Hawk Performance Ceramic pads, not considered good for track, but very effective on the street and dust free.
Changing rotors and pads is very easy, with internet instructions easy to find. No special tools other than a pad spreader if you want to use one.
I'd stick with the OEM pads & rotors for a street car. Probably the most cost-efficient too.
Most aggressive track pads will squeal like a stuck pig. Or an old garbage truck.
However, if you insist:
Girodisc rotors are great on a Cayman.
The Ferodo DS1.11 pads are great. Some of the less aggressive Pagid pads (blue or orange) are also good on a street car.
Thank you - Do you know who sells kits
Thanks for the help - do you know who sell kits? Everything I need - pads - rotors- sensors - pins - screws etc.?
Unless you're tracking the car, the stock pads and rotors will last a pretty long time. Porsche OEM stuff has a gazillion $$ in development invested in it. Just sayin'.
https://www.suncoastparts.com is cost-effective on the parts, sometimes have free shipping promos on orders over certain dollar amounts.
It's a good time to check all pads and rotor thicknesses. If you're already in there...
Good luck!
There was a rotor thread a few weeks ago and someone mentioned fcpeuro.com for rotors. Apparently they offer a lifetime warranty. The next time you need rotors you'd buy new ones, mail the old ones back, and they refund your new purchase. I looked and they seem quite competitive on prices for the Sebro and Zimmerman rotors. Cheaper than what Suncoast wants for the OEM rotors.
Definitely stick with the OEM pads if you're just daily driving. They are easily as good or better than what most aftermarket options sell as a "performance street" pad.
Personally, I tend to be a little OCD about fasteners and prefer to spend a few extra bucks just to have everything new and "up to spec." Also, new stuff is generally easier to work with. That said, the only time you really have to use new fasteners, etc is if the original is damaged or designated by the factory as non-reusable.
Thanks for all the input - I have placed and order OEM manufacture pads -textar - new rotors and all the parts necessary to do all four corners from ECS Tuners $700- they were very helpful with a complete package -
Just about half the price quoted by two independent Porsche specialties in Newport Beach? They quoted parts and labor $1090 for the fronts and $780 for the rears ($500 less than the dealer)- Pretty sure I can get them installed for less than a grand!
Also thanks for the video tips - might just do it myself!
Have a great weekend!
http://ctbrakes.com/
Their 1521 is a terrific very low dust street pad and has significantly more initial bite than the Akebono's. I've used them on several cars including the 981. The 1521's are not up to the task of track duty though. I swap out to the XP-10's for that.
1. Everyone here is smarter than the engineers that designed your car and it's brake system;
2. Everyone here is a professional race car driver with decades of driving experience and unparalled driving skills;
The guys that designed your car designed a SYSTEM using drilled rotors. Changing one part of a SYSTEM can make it work better in one area, but at a cost of performance loss in another area.
Simply put, non drilled rotors run hotter which requires a different brake pad than oem. Higher temp pads DO NOT stop as well as oem on the street. They REQUIRE more heat to perform properly.
I drive on track and on the street. I use oem style rotors and pads on the street.
I use Hawk pads on the track with the same oem rotors.
I consistently out brake guys with "better" brake pads and rotors.
Save your money and stick to OEM style parts.
You can buy OEM pads without the Porsche box and literally save hundreds.
OEM drilled rotors won't automatically crack as some suggest (even though those people think they are smarter than the engineers at Porsche)
I bought rotors from these guys in 2015.
https://brakeperformance.com
10,000 miles and 20+ track days later (twice at COTA) and they still are in excellent working condition.
