Girodisc rotors vs. OEM - what am I missing?
They are also 3 pounds heavier than stock, but they don't crack as easily.
You're also missing the fact that they are larger in diameter which offers more brake torque for the same pressure. This in combination with the improved cooling meant I've never experienced the fade I used to get with my 996 in my 987.2. I've also never felt the need to change the master cylinder for the same reasons.
Are you referring to Sebro slotted rotors? In the thread you linked there is no mention of Sebro, yet the comment on a “light” track option is referring to Sebro.
Anyway, I took the plunge and bought a set from parts geek. The price makes them a no brainer to try. They seem a bit heavy, but I’ll weigh and compare when I get around to replacing.
Yes, "light" is right. Despite the fact that they have left/right orientation, the cooling is no better than the stock drilled rotors in my experience: https://rennlist.com/forums/987-981-...l#post15209219
Yes, I replaced the OE drilled rotors with slotted Sebros as one of my first steps, but they didn't help the overheating I was experiencing on track. Totally fine for street. Even extremely aggressive street. I didn't notice the weight by feel while driving. Just by measuring what went on and what came off of the car. That's 3 pounds for all four corners.
I’m just looking for more durability than cross drilled, so maybe they’ll work for me. I haven’t had overheating issues with SRF and Pagid yellow pads.
I imagine they are fine for track for most. Better than OEM due to the cracking issues with drilled rotors. Overheating at the track depends on lots of factors, driver, track, etc. I have a buddy I used to run with regularly with at the track. We had basically identical car set-ups and ran almost identical lap times (I was slightly faster usually). He went through brakes more than 2x as fast as I did (same set-up) and battled overheating. I never had any brake overheating issues.
In my opinion he over-drove the car. He was on the brakes too much, did a lot of trail braking and wasn't a very smooth driver with his inputs (he wore his tires more than me as well). He made up for a lot of it with being very aggressive and having excellent car control when the car started to slide/need correction. If you rode with him, then rode with me you would think he was significantly faster as riding with him was a bit of a "thrill ride". The reality was our lap times were comparable and we had a great time driving together.
Former Vendor
We also have the Sebro Slotted in stock too.
https://www.warehouse33auto.com/cata...ake-Brake.Disc
-Jason
-Jason
Just as a follow up, I installed the Sebro rotors last night. If you are already changing pads, swapping rotors is really quick. I weighed the Sebro and they are 21lbs ea. My stock rotors after 4 years of wear were 19.4 lbs. This was for front rotors only.
Thanks - that is good info - will be making this change as well.
