987.1 Frunk Lining
987.1 Frunk Lining
So when I bought this car a few weeks ago, it had some known issues that I was okay with. I was able to fix all of them other than these two clips that hold the “hidden compartment” up that contains the air pump, wheel lock, etc. I found a diagram which seemed to depict what I needed but after ordered the part, it looks nothing like what’s in there. I guess I need a threaded plastic bolt of some sort, so any ideas from people who might have run into this issue themselves?
Parts Catalog
I bought part #14 from this diagram as that’s exactly where the screws are, yet it’s not the right part so I’m lost. Maybe it’s part #16 as I need a plastic screw of some sort, but that’s not the right location on the diagram and I can’t find any pics to see if it’s plastic or metal.
Parts Catalog
You have the correct part. I just went out to my '06 Cayman to check. It's a quarter turn fastener. Push it in fully into the hole and turn 1/4 turn. Very little pressure is needed. Seems to be a little tricky to fit but does work.
