'05 987 New old oil change question
Hi,
Sorry if this has been answered or is in an old thread. I did a cursory search but didn't find an answer.
Doing an oil change on my '05 Boxster. After refilling I noticed a big pool of fresh oil under the car. It is NOT from the drain plug NOR from the filter. It's more under the location of the fill port on the right side of the car. It did not overfill in the trunk compartment, but is it possible to fill too fast? Has anyone observed similar before?
I had put in about 7 quarts at this point; still less than needed. I would say half a quart at most ended up on the ground. One thing that didn't occur to me until just now is that I did not remove the oil fill cap when draining. I did let it drain for > 1 hour so it seems unlikely that it did not completely drain but is it possible I just overfilled it?
Any input appreciated.
Thanks!
Thanks!
Received 1,160 Likes
Hello Ray - I suspect you didn't receive any answers since you put your post in the Cayenne DIY subforum, where new posts are all moderated, and not visible to anyone unless approved by a moderator.
I'm moving this to the correct forum.
Hi,
Thanks!
Thanks!
What I have done with the Turbo is misjudged the oil filler tube opening and as a result ending up pouring some oil that misses the tube opening and instead runs down the outside of the oll tube.
When this happens I take a can of carb cleaner and spray the area affected by the spilled oil to remove the oil so it doesn't collect dirt nor continue to run down and make a spot on the ground.
I vaguely recall one or two cases where the oil filler tube develops a leak, develops a crack or split or comes loose somehow, but this is usually more a problem when the engine is running as the tube lets in unmetered air.
My guess is you just missed the oil tube hole with some oil.
I have an 07 987S, take roughly 9 to 10 qts. Do you have a 2.7 engine?
You likely poured to quickly and the oil did not drain fast enough. There is a small hole that drains directly under the car in the event of an overfill of the fill tube. This can happen if you overfill the engine, or pour faster than the fill tube can drain into the engine.
See the whole at the bottom between the two fill tubes?
http://www.pelicanparts.com/more_inf...70052-1120.jpg
Car was running ok, but would a cracked fill tube possibly cause these issues by pulling in unintended air?
