Anyone tracking their 981 ?
I got 16 heat cycles out of my RE71r's. They probably had 3 or 4 more cycles left, but I had to get the car prepped for a weekend at Road Atlanta so I needed to get them changed. I was at the Smokies event last week at AMP, which is particularly hard on tires, so I probably could have gotten more cycles out of them. I really like the tires, just trying to find some more time with the R7s. Glad to hear you are happy with the Giro rotors. I'm running in CHIN red (advanced) and my Cayman S times are about 2 seconds faster than best times in the GT4 track database at the tracks I run, so I'm pushing the car pretty hard. Here are some recent laps from Barber.
I'm using a BGB Motorsport bolt in harness bar with halo bar. Fits nice, seems pretty robust and completely reversible should that ever be desired. Sparco seats on Brey Krause sliders, but I'd probably use a different combo if doing it again due to mediocre quality and fitment.
https://youtu.be/qCx08sIbqK8
Thank you,
PS - if you are not already signed up, join our PCA Father's Day weekend @ BMP. Signup is at www.clubregistration.net
Couple of questions for guys tracking their 981's regularly. Anyone find a source for caliper studs for the 981S?
It seems from the discussions on planet 9, that center radiator is a must. Any data on engine temps from guys running without one?
How is tire wear without gt3 control arms? Are you guys running r-comps (e.g. hoosiers) able to get enough camber with the stock control arms (what's approx. max camber with stock control arms)?
Anyone try the X73 sway on the rear to improve understeer vs. available adjustable fr/rr setups (e.g. TPC)?
I've been getting my caliper studs from Girodisc. I use new studs (oops, I meant bolts) each time I change the rotors.
Not sure what they have been saying at P9 but my track oil temps have been stable at 244 max without the central radiator. (2.7 L). Since the car also stabilizes at this same temp during ordinary summer driving I figured that it is designed to operate at this temp. Maybe with some performance mods the temp may run hotter?
I'm running X73 and got close to 2 degrees camber all around with everything else stock. It may have been a little under, but not much. Tire wear has been acceptable. Running NT01s and RE71Rs. Hoosiers are the next level up in grip, and I haven't gone there yet..
Basic Sponsor
I'm selling the race car and trailer etc and going back to DE and Track days. While I decide what car to buy for the purpose I was considering tracking my 981 GTS. Anyone tracking thier 981? Any issues, overheating - oil or PDK ? I won't be tracking it extensively but would like to use it while I shop. Could see 4-5 track days.
Jeff
Jeff
Jeff
Jeff
A friend has a 981 GTS which they moved to after a base 981 for a year. Both see track time although he usually tracks his GT3. I've driven both of his Caymans at the Glen. Spectacular car and lots of fun. Ran great - zero issues. I agree re upgrading brakes. His were bone stock and don't see enough track time to warrant mods.
I have Tarett caliper studs on the GT4. Haven't had a pad change yet but I know it'll make it much easier.
Did you see this thread about going to a smaller wheel size? This pertains to the GT4 dropping from 20 to 19, and I don't know if all 981 would be affected in the same way - but worth understanding to avoid an issue. The first post gives details and photos.
https://rennlist.com/forums/gt4/9891...eels-read.html
Good luck!
Basic Sponsor
At this point only Cobb has the ability for us to do this remotely with their Accesport and custom ECU file. Since you're an S, you have a throttle restriction and since you're a Boxster you have a further throttle restriction. You are 2 steps behind a Cayman GTS BUT it's all just a matter of software.
Location: On a pygmy pony over by the dental floss bush
