Porsche 981 Cayman GTS Recaro Profi XL Seats and Roll Bar Install
Basic Sponsor
Attachment 1344394
To get this Porsche 981 Cayman GTS for ready for the track, we installed our BBi StreetCup Roll Bar, Seat Base & Slider Kit, and Recaro Racing Seats to properly mount Schroth Racing 6
point harnesses. Here are some pictures of the build progress that we would like to share
Upgrades & Services Performed:
Safety Package
BBi StreetCup Roll Bar in Satin Black
Key Features
Next, we installed Recaro Seats with our BBi Seat Base & Slider kit to install 6 point harnesses and properly secure the driver and passenger.
BBi Seat Base & Slider Kit Porsche 996/997/991/987/981 Seat
The BBi Autosport race spec seat mounts are a direct bolt-in to the factory mount location for a hassle free, easy installation for your competition race seat. The BBi Autosport Seat
mounts have a large range of adjustment options allowing fitment for all major FIA and SFI approved seat brands and offers an integrated 5 and 6 point sub belt mounting location.The wide
range of adjustment covers almost all possible seating preferences to properly seat drivers of all sizes. CAD designed, CNC laser cut and formed from one piece of .125” (1/8”) carbon steel
with no welds to maximize strength and stiffness. All mounts are powder coated with a wrinkle black base and satin black sides.
Features
Safety Package Install Completed
- Jerry@BBiAutosport.com
Safety Package
- BBi 981 GT4 StreetCup Bolt-In Roll Bar
- BBi Seat Base & Slider Kit
- Recaro Profi XL Seats
- Schroth Profi II 6 Point Flexi-Belt Camlock Harness Set
Key Features
- Chrome moly steel tubing utilized for excellent strength to weight ratio
- Modular construction to allow access to engine for servicing without removing entire roll bar
- Shoulder harness mounting crossbar positioned at appropriate height as per Schroth's instructions
- TIG welded and utilizes "X" braces on rear section for superior strength and rigidity
- Mounts to frame structure and rear strut tower to provide strongest mounting points and maximum protection
- Utilizes laser cut mounting plates & inner diameter tube clamps that are CNC turned and milled for a precise fit
- Designed to work with stock or any aftermarket seats on the market
- Minimal effect on seat travel to accommodate taller drivers
- Can be used with stock seatbelts or 6 point harnesses for track use
- Designed to work with wrap-around style harnesses while optional eyelet bolt provisions are available for clip-in harnesses
- OEM fit & finish. The main hoop contours entire arch of the roof with an even curve
- Finished in satin black powder coat. Other colors available
- Bolt-in installation requires no drilling and minimal carpet trimming
Features
- Precision CNC laser cut and bent from one piece of 1/8” 3mm carbon steel (base & side mounts)
- Multi way adjustability
- High strength sliders, mounts to base with 4 bolts per slider
- Integrated 5 and 6 point sub belt mounting locations
- Stylish design with laser cut BBi logo and durable satin black Powdercoat finish
- No modifications to vehicle or any seat mount components are required for installation
- Uniquely designed for Porsche vehicles for the best possible fitment
- Mounts to factory bolt locations with precise factory fitment
- Fits all major FIA/SFI approved seats up to 17”
- 14-3/4”¬(375mm) to 17-1/2”(445mm) width adjustments (standard side mounts)
- 16”¬(375mm) to 18-3/4”(445mm) width adjustments (optional wide side mounts)
Bringing Passion, Artistry, Craft to the Porsche Tuning Industry
Southern California's Porsche Performance Tuning, Engine Development,
ECU Software Tuning, Custom Fabrication, Race Preparation & Factory Service Center
Website: www.bbiautosport.com Email: sales@bbiautosport.com Phone: (714) 843-0200
Follow Us On: Facebook & Instagram
The following 2 users liked this post by BBiAutosport:
amalitsky (06-30-2023),
IndigoInkTaco (02-04-2022)
3 pt seatbelt received
Hi I have the same car and am installing the same setup for DE track use. One hurdle is when I remove the factory 14 way seats, the 3pt seatbelt receiver comes off with them. If I remove it to install with the Sparco seats, where do I install the canble, as it does not have its own socket in the plug coming out of the floor. Its part of a bunch of wires in a larger socket. Any assistance is appreciated. Thanks
If you look at the connector on the seat side, you can see the each cable goes into a plastic housing that houses all the individual connectors to make it look like one big connector, using a small flat head you can remove the connector for the seat belt from it. Then cut all the zip ties to remove the cable from the seat.
Also curious if you felt a noticeable difference in the vehicle once you installed it. Did it add any (perceived) change to how the car feels and handles? I had a bolt in cage in a previous car and it made a noticeable difference. Wondering if that holds true across the board, or if that was just a result of a vehicle that could've used more points tied together to stiffen things up.
