10mm lowering BS 981
Hi ,
I have a stock Boxster S 2014 and I would like to lower it a little bit . I looked at the X73 SS but 20mm would be too low due to ground clearance issues in my area .
I was wondering if PASM springs could fit on my stock shocks ...( spring rate is a little bit higher )
I also had a look at the Bilstein coilover B16 PSS10 witch can be lowered 10mm ( am I correct ? ), but was wondering if it will not be too stiff . How does it compares to the X73 SS . I've been searching forum extensively and could not find an answer .
Thank for your advise .
