981 oil filter fit
981 oil filter fit
When inserting the new oil filter in the housing before reinstalling the housing, I noticed the upper tube has very snug fit when it is pushed into the filter hole. The lower hole of the filter, however, is a loose fit around the filter housing centering cup. How does porsche keep the oil from bypassing the filter at this this loose fitting joint?
Is there a flow diagram explaining this? Or a good explanation would help to ease my mind.
Taildragger-981 dark met blue
I bought a filter online for my Cayman and when I compared it to the factory filter there was enough difference I never used the filter I bought online but stayed with the factory filters I bought at the dealer parts department.
My recollection from when I changed the oil is the filter gets compressed some when the housing is installed and tightened. I would install the filter into a clean housing pushing the filter down until it seated on the spigot at the bottom of the housing, then dump in fresh oil to fill the housing up then carefully install the housing.
The filter doesn't get squeezed too much but it gets squeezed enough the covering at each end ensures an oil tight seal so the oil of course passes through the filter element and can't flow around this.
