2014 Cayman Computer Options
I'm taking delivery of this car in a few weeks. Is there a list somewhere that describes the configurable options available for this car? I'd like to figure out if I want any of the default settings changed.
I had to download the owners manual and harvest the various settings from it. The options were 'buried' within each section.
Don't depend on the salesperson or even the techs to know all of the possibilities. I was told more than once "you can't do that". I ended up sitting with the tech while he thumbed through the PIWIS.
It also depends on if you have the PCM since it offers more configurable options than the standard audio head. IIRC the PCM allows you to set things that only can be set with the PIWIS on the standard head unit.
Good luck!
BD
Good luck!
BD
The main thing you will want to decide is if you want the horn to "beep-beep" when you lock the car...if not the dealer will need to turn that feature off. Beyond that I haven't needed to have the dealer do anything else for me.
