981CS Engine Cover Removal Help
Could someone please describe the exact process of removing the carpet panel over the engine cover? I haven't tried yet but according to planet-9 posts it's not as straightforward as the previous model. Thanks.
Figured it out this afternoon while doing the X73 suspension upgrade. Remove rear lower trim pieces (2 on each side to uncover the tops of coilovers. Then remove the alumi-look cross piece and fluid caps. Then lift and slide carpet and foam towards rear of car.
