Impressions of my 981 Boxster w/ BGB 3.8L 991S conversion
I would love to see more photos of your car in general and also know more about the 991 motor you have. Is it a BASE 3.8 or can you get the X51 stuff, Sport Exhaust (with button) option, etc. Also, forgive me if you stated it but can this be done with a PDK Car and is your car PDK?
Thanks so much for this write up!
My car is a 6sp but I believe this can be done w/ PDK as well.
Yes sorry typo, should read 2.7L not the Boxster S motor which would have been 3.4L like the 991 base.
Excellent work! Great post. The car looks gorgeous. Bare-bones, low-option, base 981 + a $21k 3.8L 'option' may be the best bargain in Porschedom and roadsterdom. Maybe Porsche will see the light if BGB started doing 200+ of these conversions a year.
I agree with the others: thanks so much for sharing your story with us and it gives me something to think about as my 987 Boxster ages and I'm thinking about what to do next.
Great price, too, when you think about it. Not much more than the X51 option on the 991s!
You upgraded like a boss.
p.s.
aside from the master cylinder, what else from the GT3 (that doesn't cost as much as the donor car) can be potentially upgraded by BGB?
p.s.
It's the "base" 3.8L motor of the 991 Carrera S. I'm not sure if this could be done w/ X51 or sport exhaust, I imagine the latter would be tricky given the size/shape differences with mid-engine placement. But presumably there are or soon will be a wide variety of aftermarket exhaust options.
I would love to know if these guys could put a monster 3.8 inside my Cayman R???
GT3 player par excellence
^yes, bgb will put 3.8 in to cayman. in fact, they have done several already
So happy to see someone moving forward with this conversion. You're giving me ideas...bad bad ideas. ![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
By the way, if BGB is following, big time congrats for sweeping the GX driver and team championship. Pretty cool to see an independent Cayman battle against factory backed Mazdas.
Al Allen (11-25-2021)
awesome project...nice job and nice major mod! Congrats and keep us posted...
I am in RI as well, if you ever get to Newport would love to see it.... we can take my RUF Turbo R Conversion and your Boxster 991 Conversion out for a ride!
again, nice write up and thanks for posting... I have to say these new 981 are amazing cars....
Basic Sponsor
First and foremost, I want to thank Lee for having the faith in us to do this work, for his patience during what was a very hard season running 3 cars and building more AND for his gracious writeup on the Rennlist.com site. I had to renew our sponsorship, so I apologize for chiming in late. I will attempt to answer all questions as best as possible per my recollection.
1. This job is somewhat really hard to do when trying to slam any type of 997.2 engine into a 987.1 car. A lot would be invested in pinning out control units, running the DFI pump, etc and therefore we have stayed away from crossing generations. If you have a 987.1, you need a 997.1 X51 swap and that's a cap of 385crank hp and 300lb/ft. The 997.2 engines are much more robust, reliable and worth the bang for the buck. The most power that you could deliver to a 987.2 would be with an X51 9A1 DFI engine. Lee's car gets the benefit of aggresive tuning from the stock 991 software and it's rated at 400 crank hp and 325 lb/ft of torque at the crank and as you can see from the dyno comparison to our 991, it's awful close. BUT withou a Motec dash, it's hard to control the variable intake runners that are really what make the X51 engine. The 997.2 "Power Kit' head is not really the CNC ported head we think it is. the valves aren't different nor are the camshafts. HOwever, the cost of the X51 engine core has come down from $25K to $12K. So that's promising.
2. We did dyno the first car. that dyno graph is attached. I was in a rush to get Lee's car back to him and I was not there to dyno it. The graph from the Cayman with the same parts however is attached.
![](http://bgb-motorsports.smugmug.com/PorscheRaceorStreetCarBuildout/2013-981-Cayman-38-Conversion/i-vRmsMRJ/0/M/BGB%20981%20vs%20991_3.8L%20Swap_May%202013-M.jpg)
3. Unfortunately Lee's DME is stock and is in need of a flash. It will be a few months still before the new 991/981 software from Siemens is hacked. When it is, all these cars need files. They're totally stock and the only reason I was able to crack the code on the tuning WITHOUT tuning is because the new cars use a MAP sensor, not a MAF sensor. Therefore, the ECU is even more ignorant to the fact that it has a fire breathing dragon in the hole as opposed to the little 2.7L DFI gerbil. Lee's car got air filters but is in need of a bigger throttle body, plenum and a race file. The first Cayman we built apparently wasn't powerful enough and that car's owner was kind enough to commission us to install the 991 Power Kit heads. NOW THAT IS A MOTOR. The heads are actually ported and it comes with bigger valves and a different cam shaft. It's a worthwhile job.
I appreciate the kind words and support from the people on here. If you have further questions, please call or write. I will try and chime in more often.
Thanks.
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
Basic Sponsor
1. This job is somewhat really hard to do when trying to slam any type of 997.2 engine into a 997.1 car. A lot would be invested in pinning out control units, running the DFI pump, etc and therefore we have stayed away from crossing generations. If you have a 987.1, you need a 997.1 X51 swap and that's a cap of 385crank hp and 300lb/ft. The 997.2 engines are much more robust, reliable and worth the bang for the buck. The most power that you could deliver to a 987.2 would be with an X51 9A1 DFI engine BUT
Thanks.
RUF is probably the best known tuner of Porsches. They both do aftermarket conversions and also manufacture "new" cars where they start with a fresh chassis from the factory and build it into full OEM RUF car. The latter carry a RUF VIN number, the aftermarket conversions still have their original Porsche VIN.
http://www.ruf-automobile.de/index.php?lang=en
