View Poll Results: 981 Boxster Spyder? Or possibly too good to be permitted
Of course!
9
56.25%
No way...
7
43.75%
Voters: 16. You may not vote on this poll
Will there be a 981 Boxster Spyder?
#47
As we haven't even seen a Spyder mule yet it could be possible the Spyder will get the same bits as the GT4 and some cosmetic make-up which means there is no need to test a separate mule as the GT4 already covers the testing?
Either way you guys should be happy with the 3 new models coming this Easter
#48
I can confirm this is correct information based on my conversation with 3 UK dealers.
#49
Looks like no Spyder for the 981.... more of a Boxster GT4!
http://www.carscoops.com/2014/12/new...orking-on.html
#50
#51
This makes sense, same carryover that occurred between the Spyder and Cayman R. More power, better suspension, maybe better brakes and likely standard LSD. I'm curious if they will also try to make it lighter. Would be a major bummer if it onlyl comes with PDK though.
#52
#53
#55
#56
The spyder concept was a minimalist approach that looked to cut weight to the bone to improve the performance of the car. If this new boxster has an automated top - and the weight along with it - it's no spyder.
#58
As has been mentioned there was probably no way you would get a 981 light weight car, the design of the 981 is beautiful as is and frankly still has another cycle before its replacement is ready. The 987 was the perfect platform to build the Spyder as it was already earmarked for replacement, a little more "raw" than the 981 across the spectrum and probably the last of the purely mechanical Porsches to be made from the sense of absence of science fiction electronics. Look at the interior alone of the 981 from the gauge cluster to center stack...these are no longer the entry level Porsches as they once were but have taken many parts from the 911 and other more expensive Porsches. So if one were to build a Spyder today what would you remove? How would you control the options as not to add hundreds more pounds? I don't think you can even remove the double Din on the 981 because it feeds to the display on the far right gauge now. Then there is the top....Porsche spent a lot of money and time designing the Spyder as a concession or homage and they were rewarded everywhere but the point of sale. I think we will see a Speedster Boxster which would allow them to keep everything but not a LW Spyder...those days I believe are gone.
I had a E30 M3 and a E36 LW M3 and now look at the M3. Great cars to be sure but not those in any stretch of the imagination no matter how exotic the material used to lesson weight. Look at the Alpha 4C for a lesson to see how a LW no frills sports car will fare. As Motor Trend just said " A great 5th car"
#59
Yes you guys are correct. If they could reduce the weight noticeably Id love to buy one... But look at the new GT3 - the car could have been lighter but technology like RWS was added, though its benefit appears to have outweighed the weight cost.
They say hope is the last thing to die... I have hope for a light weight Porsche.
#60
