Hi all. I recently acquired a 981 GT4 and planning first track day with it. The car has RE-71RS, and I would like to know what pressures are recommended. Tires are relatively new, no noticeable wear. Thanks.
Post this question in the Performance and Driver's Ed Forum under Performance and Competition Areas. I run Hankook RS4s on a 2013 Boxster S with hot target of 34-36 normally starting at 26 depending on temps. Immediately check and adjust after each run. Add air at the end of the day or tires will be extremely low the next morning. Expect to P off your TPMS. It normally resets overnight if you air up at the end of the day.
okie981
close
- Join DateJan 2016
- LocationOn a pygmy pony over by the dental floss bush
Liked:785 Times in 531 Posts
I ran RE-71R on 19" rims, 255/285 F/R, and starting at about 26 psi would end up at around 35 at end of 25 min session with even tire temps across the width of the tire once I got my camber dialed in.
thanks. appreciated.
ExploreRennlist Member
thatbrownCS
close
- Join DateSep 2022
- LocationMiami, FL
Liked:242 Times in 112 Posts
I agree with okie981, I start around 25-26 cold. In my experience the RE71 have a narrow optimal operating temp. You ideally want to stay between 32-35 lbs hot. Anything outside of that and they start to fall off quickly. But they are excellent and do hold the temps well when you get them there.
