Shifting to Neutral with paddles, PDK
I called and spoke w/ the dealership today and they were "90% sure" that this feature cannot be programmed into the car if it did not come stock with the sport design wheel w/ paddles.
Seems my only option if I really want this feature might be to use the Cobb tune.
Really hopeful that someone with more knowledge can guide me in the right direction if the dealership is mistaken. It seems this should be an easy change if an aftermarket tune can do it.
I've also reached out to Suncoast to see if they have any suggestions but haven't heard back from them yet.
EDIT: Sorry, this is essentially a duplicate. ICNU said the same thing above...
I remember reading that the Cobb tune method is slightly different. I want to say that it's a "temporary neutral" meaning that it goes back into gear once you release both paddles? Not really sure about that, but you might want to investigate further before spending the $. I know there's something different about it, but I don't remember what exactly.
Not sure the Cobb is worth it to me just for that though.
![](https://cimg8.ibsrv.net/gimg/rennlist.com-vbulletin/1280x894/img_0640_5b9e2be1c9f5ba8e11f72364ed8f75d36cc2ee86.jpeg)
I installed the Cobb AccessPort with PDK flash 6 years ago on my 2014 CS. My car came with the Sport Design steering wheel with the paddles and pulling and releasing both paddles put the PDK in neutral the same before and after I installed the Cobb PDK flash. I have always used it as a coasting function and the gear display in the cluster is blank when engaged and flipping either paddle will put it back in gear. If you come to a stop before you re engage a gear, you must have your foot on the brake to flip a paddle to put it in first gear.
It looks like from the Cobb description above that the Dual Paddle Neutral function will only work with an upgraded steering wheel with paddles if you use either their Cobb Sequential Style or Cobb OEM+ map. The map I use and prefer is the Cobb Aggressive map (older version V202). I have PIWIW2 and have not looked into coding a new wheel but I would guess that you would need to change the coding of the wheel to the Sports Design wheel ( Porsche option code 840) and this would probably not work with a multi function wheel????
Jim
Just wanted to provide an update here for posterity sake -
According to dealership and Suncoast, I am told that it is not possible to change the way the wheel functions if the car comes stock with a multifunction wheel with the "shifter buttons" and is then upgraded to a 718 style wheel with paddles.
It can be done with a 991/981 Sport Design wheel with the MF stalk, however.
So if you're planning on installing a 718 multifunction paddle wheel and the double shift to neutral feature is important to you then also consider getting the Cobb tune.
If anyone has been able to find a workaround for this please let me know but this is the information that I received from two dealerships and Suncoast.
