Rattle Behind the Dash
Hi all, I had a new rattle develop seemingly over night and I'm hoping someone here has experienced something similar and can point me in the right direction. It went from no noise one day to constant rattling the next. It's hard to localize the sound, but it seems to be coming from behind the instrument cluster and sounds like there's a tiny pebble bouncing around on plastic. The video shows that it rattles pretty aggressively even on fairly smooth surfaces at low speeds. Side to side motion doesn't seem to trigger it, but vertical bouncing does. Any ideas?
The first thing I would do is pop open what is accessible without a screw driver, so it the center speaker cover and the above dash cover and take a look.
I had sounds coming out when my center speaker blew, changed all the speakers and never heard the noise again.
good luck
good luck
danby (02-29-2024)
Congrats on finding it..
I've had a loose passenger seatbelt make a noise that sounded like it was coming from under the passenger dash/front wheel.. Just reset the seatbelt and no more noise.
I've also had a small money change dispenser in the driver door storage compartment make noise like it was coming from under the center dash. Settling the coins makes it stop.
Weird how sounds reflect inside the cab of the Cayman.![Confused](https://rennlist.com/forums/images/smilies/confused.gif)
