981 Forum Discussions of the 3rd Gen Boxster and 2nd Gen Cayman (2012-2016)
Max wheel offset
Old Sep 26, 2023 | 07:40 AM
Arczi001's Avatar
Arczi001
2nd Gear
Default Max wheel offset
Hi, i have a question,
I have a opportunity to buy wheels with parameters :
20x9 et 40
They Will fit to cayman 981?
Especially the front
Old Sep 27, 2023 | 03:56 PM
SnowmanMafia's Avatar
SnowmanMafia
I don't think that would fit on the front.
I'm running a 20x8.5 et57 with a 7mm spacer so that's effectively et50 and the wheel is almost flush. Some people run 10/12mm spacers so that would be 47mm or 45mm effective offsett.
A 20x9 et40 would give you 4mm more clearance inside but extend 16mm mm further than my setup and I think that may poke excessively.
Apex has a good fitment guide and their most agressive setups are running 9 inch wide wheels with an et46 up front.
https://apexwheels.com/fitment-guide...ment-guide#oem
Old Sep 27, 2023 | 08:10 PM
NineATE1guy's Avatar
NineATE1guy
20x9 et 40
I found this online offset calculator about a year ago. Could give it a try.
https://www.1010tires.com/Tools/Wheel-Offset-Calculator
Old Sep 27, 2023 | 08:34 PM
IndigoInkTaco's Avatar
IndigoInkTaco
I was going to link to the same thing. The apex guide is a great reference.
Old Sep 29, 2023 | 11:05 AM
Arczi001's Avatar
Arczi001
2nd Gear
Ok, this is not what i wanted to hear 😂 but thanks for the hints
