981 Forum Discussions of the 3rd Gen Boxster and 2nd Gen Cayman (2012-2016)
Cayman transmission dimensions
Old Sep 18, 2023 | 05:18 PM
johsva's Avatar
johsva
2nd Gear
Default Cayman transmission dimensions
Hi, new member here from Sweden,
I have an odd question that I couldn´t find any answer to. Is there anyone that knows the dimensions on the Cayman PDK transmission? Like lenght, height, distance between the output shafts for the CV´s, distance from the bellhousing plane to the output shafts etc..
The reason I ask is because I´ve built a GTM Supercar that currently uses a G50 transmission and like to convert it to a PDK.
I´ve seen the PDK on pictures and it looks bigger in some areas, not sure that it would be a problem. But it would be great if I could have some help with this so I don´t buy anything I can´t use. The G50 is a nice transmission but when they are this hard to find I rather go for a more modern unit
Thanks in advance
/Johan
Old Sep 25, 2023 | 05:23 PM
toma nova's Avatar
toma nova
Search Youtube for Jeff Richardson - he's done an incredible amount of research into PDKs.
Might also look at the videos from Atlanta Speedwerks (shop that did my rebuild) or Champion Motorsports.
Old Sep 25, 2023 | 05:25 PM
johsva's Avatar
johsva
2nd Gear
Might also look at the videos from Atlanta Speedwerks (shop that did my rebuild) or Champion Motorsports: https://www.youtube.com/results?sear...=pdk+tear+down
Great. I’ll give it a try.
Thank you
