Heater core pipes hot
Hi 2016 cayman base. While hiding some wires under dashboard i noticed the heater core pipes were real hot. AC and heat work well but wondering if pipes being hot is normal or an issue. Thanks in advance for the help.
dan
dan
Its going to be normal with running the car and working in that area after the car was ran for a bit to get the coolant hot. Some cars have shut off valves in the line to the heater core loop to only allow coolant into the heater core when you request heat. But that is a potential failure point where the valve is normally vacuum controlled and could fail. The normal operation of most HVAC systems in cars the air flows through the evaporator first then depending on if you have hot or cold selected is how much the air bypasses the heater core.
