981 Forum Discussions of the 3rd Gen Boxster and 2nd Gen Cayman (2012-2016)
981S - Acceleration not very smooth - is this normal?
Old 02-18-2024, 11:09 AM
  #76
Sajan
Sajan's Avatar
Originally Posted by rr_gts
Is this the one you bought that came with an O-ring?
https://www.suncoastparts.com/product/SKU981CXCAPS.html
that’s the trim piece.
this is the actual oil cap.
SKU: 98110703508
Old 08-06-2024, 02:31 AM
  #77
rezilient
rezilient's Avatar
SKU: 98110703508
Hi ​​​@Sajan @subshooter sorry to bump a pretty old thread but I had a question for anyone that was having similar hesitation/stumbling issues and resolved it.
I’ve been reading about carbon build-up on the intake valves on our DFI engines and was wondering if you looked into doing a walnut blast or similar? For example: https://www.planet-9.com/threads/bef...981-cs.255957/
I’ll probably go ahead and order the oil cap anyway but am pretty confident I’m going to end up needing to blast the intake ports.
Thanks.
Old 08-06-2024, 12:21 PM
  #78
Sajan
Sajan's Avatar
Thanks.
Cars that have exhibited this had relatively low miles on them so I doubt doing something like that would help.
My conclusion on this is it's related to crankcase pressure.
rezilient (08-06-2024)
Old 08-08-2024, 10:49 AM
  #79
quantim0
5th Gear
quantim0's Avatar
My ‘15 cayman S has/had this issue of a hard stutter or power cut between 2200-2600 under partial throttle.
I loaded the Cobb OTS ecu/tcu tune and that definitely helped minimize the issue but it’s not totally gone.
Checked my oil cap and I do not have the o-ring. Ordered the part from Subcoast and will report back.
When checking the oil cap o-ring I noticed a lot of oil had burped back up into the cap area. I had just completed and oil change so I’d imagine there was some excess oil not drained into the sump, but I don’t think pressure should be escaping through that area forcing oil back up the tube.
Sajan (08-08-2024)
Old 08-08-2024, 01:11 PM
  #80
t-design
Basic Sponsor
t-design's Avatar
If you also has hesitation on start - like battery is low, and misfire errors in the report - HPFP would be my first suspect
T-Design9 : Mods and ergonomic accessories bespoke designed for Porsche cars
Memory Modules : remember SC **** settings; A/S/S, PSE, Spoiler, Sport/+ buttons
Phone Mounts : keep your phone up and close and charged
Cupdholders, Sunglass Holsters and more at T-Design9.com
rezilient (08-16-2024)
Old 08-15-2024, 10:40 AM
  #81
Renius
2nd Gear
Renius's Avatar
My well maintained 2013 Boxster S with 115,000km was also experiencing at bit of "stumbling" around 2500rpm.
It had the factory oil cap with the missing upper o-ring and had oil residue all under the cap.
I ordered a cap from the Porsche dealer for $30 CDN all-in and have been running it for a week now (400km)
I believe the hesitation is now gone or at least materially reduced! Go figure
Thanks for hard debugging work the recommendation to try this easy / cheap fix.
Sajan (08-15-2024)
Old 08-16-2024, 09:42 AM
  #82
Chrismalberts
Chrismalberts's Avatar
I never felt my 981 base accelerated smoothly from lowish revs and the Softronic tune 100% eliminated that - and of course made it feel stronger too. I think it's a trait of the car, that the careful attention of a tuner such as Softronic can eliminate.
Old 08-16-2024, 11:23 AM
  #83
rezilient
rezilient's Avatar
I replaced mine unfortunately didn't see any difference (but at least I'm using the improved oil cap at this point).
Old 08-16-2024, 11:25 AM
  #84
rezilient
rezilient's Avatar
I need to try this, thanks for the input!
Quick Reply: 981S - Acceleration not very smooth - is this normal?
