What Maintenance Items Would You Do On 70K Mile CS With No History?
Hi All,
Christmas 2021 bought a 981 CS with PDK that had 62k miles on it from a Nissan dealership, car runs great is rust free but had no maintenance history. Once I had it, I changed the oil as well as the engine and cabin air filters, oil was just one bar above min when I changed it so not the best sign but oil looked fine. I drove it all year it has had no issues, it now has 69k mile on the clock but while I have it garaged this winter I figured I'd do a bunch of maintenance to it since I have no idea what has or hasn't been done.
Here is what I'm planning, please add any suggestions.
Oil and filter
Spark plugs
Ignition coils
Drive belt
Water pump and gasket, do I need to get composite impeller?
Thermostat and gasket, do I need to replace housing?
Add center radiator
PDK Oil and pan
Brakes
Air oil separator?
Also how do I know what bolts are reusable, do I need a new pully for the water pump, what about drive pully or tensioner? Any good resources on manuals with torque specs and stuff, I don't mind paying. Haynes doesn't make a Porsche 981 manuals and I haven't found any online.
Thanks.
Oil and filter
Spark plugs
Ignition coils
Drive belt
Add center radiator
PDK Oil and pan
Brakes
Air oil separator?
Thanks.
Good list. I'd do the pullies and tensioners while you are in there at that mileage. You might could skip the PDK pan and do it a bit later with another fluid swap to be closer to having it all replaced. I'd do both the clutch fluid and gear oil (both sides of the PDK). See Jeff's helpful videos and lots of posts here and on Planet9,
motogpfan82 (02-08-2023)
Hi All,
Oil and filter
Spark plugs
Ignition coils
Drive belt
Add center radiator
PDK Oil and pan
Brakes
Air oil separator?
Thanks.
Oil and filter
Spark plugs
Ignition coils
Drive belt
Add center radiator
PDK Oil and pan
Brakes
Air oil separator?
Thanks.
motogpfan82 (02-11-2023)
List looks good, although not so sure I would do the water pump and AOS unless there were signs they were failing.
These both seem to last longer on the 981 than on previous years.
How do you like the X73 suspension? While I'm doing all of this I also have headers, a Fabspeed valved exhaust and the X73 rear sway bar I'm installing. Debating if I should go with the rest of the X73 setup or the X73 rear sway bar with some Ohlins R&T's and a 991 GT3 front bar with links. Not sure if all that is 4x the price of the X73 through.
Yeah, I know it's a bit excessive but I'd rather just get it all out of the way now that I have the time. I'm going to be doing 2-3 track days this year and more the following years, better to be preemptive now and spend a few hundred instead of risk a few or tens of thousands later.
Titanium5150 (02-12-2023)
motogpfan82 (02-13-2023)
911 coil pack heat shields, engine air filters, cabin filter, adjustable LCAs for negative front camber, 18 in wheels for track with track tires, Sebro slotted rotors, brake pads and fluid. No indication 981 water pumps need to be preemptively replaced nor AOS. Pricey but GT4 front bumper with its third radiator which vents vertically for better cooling. Check out FCPEuro Lifetime Warranty
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
Little knowledge on GT 4 bumpers. I think there are different materials. Find threads who have done or ask in new thread. Third radiator is different plus a few brackets. Still have to paint match. Think I bought TRW LCAs. Check FCPEuro, Pelican Parts, Elephant and LN. Only front. Believe rear gives -2 without mods.
