COMPLETELY disable PSM and Traction Control?
Mine does not have PTV. Has anyone tried the following? Have you tried running with both levels of TC turned off (press and hold the PSM button for a few seconds)? That will disable both stability control and traction control.
. My car is in the shop with the somewhat isolated issue with phaser timing chain and the 4 sprocket bolts sheared. Porsche switched to aluminum- and they can work their way out. Folks are replacing with steel as preemptive fix. A weak link in an otherwise excellent engine.
Van914 (01-22-2024)
Just want to share my experience during a skidpad training session.
With everything turned off, as I tried to power oversteer to initiate a slide, one out of 3-4 times, the car did something on its own and caused front tire understeer instead of rear tire oversteer. So I think with PASM off, under certain circumstances the computer still intervenes.
The good news is so far the computer hasn’t interrupted when I pushed the car on a road course with nanies off.
