Puzzling Durametric Codes
So today I hooked up my Durametric to my wife's new to her 2014 BS and it produced these codes. I've googled and searched this with no luck in finding what these indicate. I'd appreciate any help you all can provide.
Rick
1. CAN Gateway
Current Fault Codes
0401:
Current distributor, terminal 30 reset
Warning Indicator Off
Test Completed This Monitoring Cycle
Test Not Failed Since Last Clear
Test Completed Since Last Clear
Not Pending DTC
Test Not Failed This Operation Cycle
Fault Active
2. Door module front left
Current Fault Codes
(Nothing else showed up here)
3. Instrument Cluster for 981/991/Macan
Current Fault Codes
41094 / a086:
Test Failed Since Last Clear
Pending DTC
Test Failed This Operation Cycle
Fault Passive
41505 / a221:
Pending DTC
Fault Passive
16 / 10:
Pending DTC
Fault Passive
When was the last time the battery was replaced? If more than 5 years, battery should likely be replaced.
Those are just general things I recommend. Not specific to your codes. But from what you posted I don't see anything that looks concerning.
I like your suggestion of clearing the codes and see if they come back. There is not a single problem I am aware of on the car.
Thanks Bxstr
I chickened out!!! Since nothing seems amiss in the car systems at all, I am very reluctant to do anything with these codes except look at them. If I see anything different I will report back.
If you see those kinds of codes have you seen anything in your car that is not working properly?
