PDK Clutch 1 Doesn't Engage When Warm (P17B1)
AZ Boxster (12-30-2023)
#33
I have the same issue with my cayman s 981 but when it's cold and I felt some limp on 1,2 3 gears with rough changes. The codes are related to clutch pressure sensors 1&2. I have changed them and run for two days then it became worse where it down shifts from 7th gear to 6th and never go to 7th again with a winin noise from the gearbox. Any idea?
#34
Can you tell us more about the troubleshooting process? What data/codes did you collect to determine it was a pressure sensor? Any chance you did not assemble it properly after replacement? What are the codes now? Are you able to record data?
