Boxster top not functioning
The top on my 2013 Boxster S with 22,000 miles has stopped functioning, it will not go back up (good thing it's summer!). The windows will still go up and down when I hit the switch but the top does not move.
Thoughts?
Thoughts?
Do you hear any mechanical noise from the top mechanism? If not suspect something electrical like a fuse or position sensor. Try and manual raise the top and see if it will continue to close or open. Numerous position micro-switches. There are several YouTubes on tops. Not sure how good PIWIS or Durametric are in diagnosing top issues, but finding an Indy with a PIWIS might be the best unless something obvious is found.
I'd still try and manual raise the top to see it will continue to close or open. That would indicate a position sensor.
